MangoTango
Ha ha, perfect that I found this forum. I have a 2003 Jeep Liberty and I really need some sage advice because its sitting in the garage with the check engine light on and well, transmission is the culprit. I'll mosey around here for some expert opinions.
I do have questions. If anyone rec's a repair shop, let me know. I know of this place with the name Just Jeeps & More. I've never been there.
Prob's with the transmission if I can describe it.... Its as if it doesn't change gears. Just gets stuck in a lower gear at 40mph and strains the entire time. Hence, it's parked at the moment. I had a repair shop do some work on it back in September. The solonoids were replaced. I don't know what on earth solonoids do, lol. It drove ok until just last week. The code readings are P1776 Trans and P0305. I have no idea what these mean. I was just driving and as it started this mess I stopped at a mechanic I use for routine maintenance. He checked those codes.
I'm just guessing that I will likely be fixing/replacing the transmission.
It has about 87k miles on the odometer. Its an 03' 3.7L V6 4x4.
Thank you big time in advance if you can tell me how to get this thing fixed.
