Hello,
Two days ago, I noticed my heater in my Jeep Liberty 2002 stopped blowing warm air. The fan seems to be doing fine, I am just getting cold air coming thru the vents. At the same time my engine has trouble starting ( happened twice so far). For example this morning the air temp is about 30F and when I started my Jeep, it started right up no problem. I drove to a store say 5 minutes away and turned the Jeep off. I got back in my Jeep and turned the key and the starter was turning but the engine refused to turn over. I waited about 30 seconds, 'gave the engine some gas' and it turned over, I 'revd it' for about 15 seconds, and from there it ran fine. I am wondering if the heater issue and the difficulty starting is related. I started having this problem a few days ago, so I don't have any more info on the symptoms other than these. It seems to me, when I first start it in the morning, it starts OK, it is only when I turn the engine off for a few minutes and try to restart it, is when the starting problem shows up. I am wondering if the problem is a fuse, but I just checked the coolant level and there is no coolant. Can't figure out how this drained out? If this is the only problem ( will check later for a leak ) then is their a special coolant for a Jeep Liberty?
Thanks,
Jim
Thanks,
Jim
