Harmonic balancer removal
enj
CT
Just bought my first Jeep a few weeks ago and hoping I can get a little assistance. It's a 2002 Liberty w/the 3.7L and has unfortunately suffered from fallen rocker syndrome. Intake rocker on #2 cylinder fell off and broke the lifter guide right off the head. I have most of the engine torn down, but I've run into an issue where I can't seem to get the balancer bolt out of the crankshaft. I've tried an impact with no luck and can't seem to find a good place to hold it from turning while trying to use a breaker bar. Any of you more experienced possibly have a tip/trick to holding the balancer to get this bolt out? From the research I've done, it does appear that the bolt is standard, right hand thread.? Thanks in advance.
jeeptorino68
Oregon
The bolt is standard thread. So righty tighty lefty loosey. Anyways. I have always used an impact to pop it out (at least on my 4.7 v8) when re-installing I used chain through the balancer to the sway bar to keep it from spinning while I torqued it. Same should work in reverse with the impact too.
enj
CT
I'll give the chain trick a shot. Maybe my impact gun just doesn't have enough left anymore. Might be a good to to replace it.
enj
CT
For reference, this is what's caused me to rip the engine apart. Previous owner obviously didn't take very good care.
[/url][/IMG]
Wow look at all the gunk inside..Shameful ! :emotions34:
There is a reason why you do a frequent filter &...
61412[/ATTACH]"]
I put a long flat bar (from a belt tensioner tool) through the "spokes" in the balancer and then wedged it against the right side inner fender. Then used a 2 foot breaker bar with the appropriate socket to loosen the bolt. I did the opposite to torque it when done.
enj
CT
Appreciate the tips. Won't be able to get back at it until next weekend, but will report back on progress.
enj
CT
Bought a new impact and the bolt came right out. Working on it outside and the weather has been awful up here in New England, so haven't had much progress until today. Got the passenger side head off finally and thankfully the pistons all look good. On to the driver's side tomorrow and hopefully start getting it back together next weekend.
enj
CT
Hits just keep on coming with this thing. Heads are finally both off. Crawled underneath and the oil pan is nearly rusted through. Already have a new one, but this doesn't look like it's going to be a fun job at all. Picked up an engine support bar, hoping I can raise it enough with the heads off to slide the pan past the cross member.
Nothing against you as you bought it used, but it amazed me that an oil pan can rust out. My KJ is 14 years old and has 107K miles on it. The oil pan and transmission pan are still shiny....
Winter & road salts eat stuff bad. We've seen some real cancer/rusted pans in the forums.
If you want parts to last, got to keep it clean, & throw some paint on it for extra protection.
61570[/ATTACH]"]
Even with a new oil pan, I'd give a few more coats of rust paint externally before installing it.
Salt *****! :emotions34:
Mine covers itself in oil, Jeep really did a good job with the self rust proofing. :D
enj
CT
It's not completely rusted through to where it's leaking, but while I'm removing it to make sure the pickup screen isn't full of gunk like the passenger head was, I may as well replace it. I'll post up some pics when I get it off.
enj
CT
Here's what made me go ahead and replace the oil pan:
enj
CT
Finally got it all back together and on the road. What a long job only being able to work on it on weekends.
