GREATTTTTT more problems.. any help?
kjweston
Boca Raton, FL
Today I drove back to work from being on my break and the jeep was running fine. got back in two hours later to leave and.... My speedo isnt working, my odometer isnt working, my radio isn't working, my EVIC wont count any numbers.. and NO CEL.. When I first saw the speedo not working I thought it was my rear speed sensor but I replaced the sensor and the harness like 8 months ago. and when it was bad before it was throwing the code.. In addition to that, I went under to inspect and noticed a sludge/grime buildup on my rear sway bar, control arm, diff housing, and axle tube. The thick stuff is on the sway bar. I wiped some off, rubbed it a little to woft a smell and I'm pretty positive its gear lube. questions at hand: Could my diff be leaking out of where the drive shaft goes into the diff? Could this in turn cause my speedo problems? If not, anyone know why it would quit working and NOT throw any codes?
kjweston
Boca Raton, FL
pics: sorry they are terrible quality.. dont have a cord for my camera so i had to take pics of the pics on my camera with my iphone then email them to my comp..
bmrrwolfe
North Olmsted, OH
It looks like a rear pinion seal..
I had the same looking issues near the rear diff, and just kept an eye on the fluid level until one day it was real bad and knew it was time to get it done. Ended up costing $110 at the Jeep dealership and was done in 2-3 hours, as I didn't know of any driveline shops, and the dealership was good at some previous work and guaranteed there work.
Not sure on the CEL issues though..
I would like to hope that the leak and electrical are separate.
With no codes, and the dash & radio out, there must be something in the connection dept gone south. Start at the battery and terminals, battery passed load test lately?
The dash harness connections etc...just trying to throw some stuff out.
I hope you can find out WTF is happening, electrical stuff sure *****.
kjweston
Boca Raton, FL
Well now my radio works. So I'm thinking there might not be enough fluid in my rear diff and that's what's messing my rear speed sensor up in turn not sending any info to my dash. I called jeep and he said to bring it in for a free diagnosis so Ima take her to the stealership one of these mornings and see what they can do about the leak. Thanks guys.
Ry' N Jen
Did you top up your blinker fluid yet?
bmrrwolfe
North Olmsted, OH
Yeah learned that the hard way...
I forgot to check my blinker fluid and my engine fell out driving down the highway.
Luckily I keep a spare in the trunk.
Remember kids don't be stupid, check your fluid!
(yeah I know doesn't rhyme that great.. )
kjweston
Boca Raton, FL
damn. Checked the level in my rear diff and its normal. right at the bottom of the fill hole. and its still looks pretty damn clean. i hate when the solution is unknown. =[ dealership here i go..
Warren.fischbeck
Alton, IL
Was it only that one day? Sometimes electronics have a way and go bat-:favorites68:-crazy for a day and then is all better...
kjweston
Boca Raton, FL
took her for a ride and its not fixed.. but the CEL is throwing 0500 which if I'm not mistaken is vehicle speed signal circuit or something like that.. hopefully The dealership will take care of the seal and the sensor for less than an arm and a leg.
bmrrwolfe
North Olmsted, OH
Ask them for a quote at least on the seal, if that is what they find wrong!
kjweston
Boca Raton, FL
I'm taking her there after class tomorrow morning. The service guy i talked to said he'd do a full free diagnostic. I feel like it wouldn't have been free at my old dealership..
