Puddle Jumper 2.0
I am getting a message on my dash that says gas cap loose and I know it’s indicating a vacuum discrepancy thanks to the fabulous environmental protection agency in there. Hyper responsibility to worrying about stuff. We actually pump out of the ground and as part of the ecosystem in the first place, but I digress I’ve replaced the gas cap as well as some of my emissions components in the engine compartment. I’ve checked all the hoses by removing them and flexing them repeatedly in multiple directions to look for cracks, and none of the nipples appear to be broken and I’ve replaced the gas cap itself with a Factory gas cap and I’m still getting the same indication I’m beginning to think that the gas tank filler assembly between where you stick the gas pump nozzle in and the gas tank may need replacing and I’m wondering if anybody has had any experience with troubleshooting this part of the system or if you have any other suggestions on where to look for the problem. Thank you to all who reply!!!
