rbtconsultants
So, we pulled the fuel rail as part of the removal of the 3.7l from our 2002 liberty. The engine is back in and we're putting everything back together but I have a concern. If you look at this picture of an injector you'll see there is a little Cone shaped plastic piece on the end of the injector (brown piece far right in pic). 5 out of 6 of our injectors came out without that plastic cone. They are lost now, probably remaining in the heads that got replaced.
Is this plastic cone piece necessary? I'd hate to have to buy new injectors because I can't find that cone available anywhere. I bought o rings for the injectors and they came with little blue "pintles" that I thought were the replacement but they aren't the same, they look like little derby hats with a pinhole on top. They fit, but my guess is they would not function the same as the cone which is wide open rather than having a small pinhole.
Thoughts?
Thanks
Thoughts?
Thanks
