Front Differential Bushing Replacement??
tyates007
I am ready to put my differential back in after doing the 4.10 regear and DTT upgrade. I have the Creative Steel bushings that I want to replace as well. I really did not think this would be the toughest part of the job but I cannot for the life of me get the old bushings to come out. I can’t get them into my hydraulic press. I put penetrating oil around the edges, have tried my air hammer, ball joint press and still no movement. I am ready just to torch them out and try to cut them from the inside. Any help on what I might need missing would be appreciated. If these were the first bushings I had ever tried to replace it would be one thing but it’s not. Normally I see them with one side larger than the other so they press in one way and press out the other. These look like they can go either direction.
duderz7
Weiser, ID
I don't remember exactly how I went about it, but I don't remember it being too much trouble. I either used my press or a ball joint press.
tyates007
Thank you. I am going back at it this morning with a new approach and new found patience
vlad588
Vancouver
The two you gotta press out, no way around it. One just the rubber has to be removed, heat the outside with a torch and use a socket to push it out, once it’s hot enough it should pop out pretty easy.
tyates007
Thank you both. I was able to get them this morning with my 20 ton press. Even with that they were super stubborn. I ended up putting pressure on them and then some heat on the outside and then the freed right up. Just needed a new day and new perspective. It’s all assembled and going back in today!
