Adam f
2005 Liberty 3.7 automatic. Radiator fan comes on but only runs for 3 seconds, then ***** off for 10 seconds, then comes back on for 3. Never stays on. As a result, the a/c overheats and gets warm. I disconnected the coolant temperature switch on the manifold, and the fan turns on high and stays on. I swapped relays around with the blower motor relay and it still kicks on and off. I replaced the coolant temp sensor and still kicks on and off. I don't know where to go from here. I'm thinking ECU? Is that what controls when and how long to turn the fan on and off?
