Dual transfer case setup...
ridenby
Gold Supporter
Kentucky
I think something like "box for rocks" might work. Looks like plenty of room anyway.
J-Thompson
just south of doucheville
I've been able to catch up on my reading of my
Periodicals...
I have read several articles about Yota owners running
dual transfer cases in their Rig's.
So...
Is it possible to run a dual transfer case setup in a KJ?
Look into the doubler they make for the JK
should work fine for your KJ
same trans and basically the same t-case
would give you
1 to 1
2.73 to 1
and I think
7.45 to 1
let me google it
yup
called a rubi crawler by advanced adapters
We know about the Rubi Crawler, Jen and I will be getting
one around Christmas...
I was just wondering if anybody has ever tried a dual
transfer case setup in a KJ? I figure it would cost allot
less than the $1500.00+ Rubi Crawler add on!
It would run about the same or more then the RubiCrawler.New driveshafts will be needed which is a big cost over the RubiCrawler(none needed).You could do a 203/205 doubler but weighs like 200lbs,or get a 4 speed Atlas.
J-Thompson
I plan to one day do a flipped 300 in the TJ
not sure it could be done in a KJ
the Rubi crawler is not an option as I have the TF999
but the 300 and adapter will work
add to that a 4 to 1 kit and for about $1500 including the cost of the case
I will have a gear driven 4 to 1 case with twin sticks
and I know of a company that will build me a new skid that will give me
another 1" or so of ground clearance ,frame rail to frame rail NO drop
yeah that will put the cost near $2000 but I need a new front drive shaft
any way or will by the time I do this
the splines are wearing in the slip joint same for the rear
Ry' N Jen
Interesting what Troy mentioned as far as cost is concerned. The Rubi Crawler looks more appealing and less work compared to messing with two transfer cases! This is why I asked the question...
Also cool what you have planned J. Sounds like good bang for the buck!
