Dual Batteries
uscgbazz
Texas
Howdy all, has anyone done a dual battery setup? If so where did you mount te second battery? Thanks!!
Moon
Texas
Uuuuum.... no, but you've certainly got my attention.
I can't help you with that question, but I gotta ask.... why do you need two batteries ??
:cheers:
moparman
Baltimore, MD
I've seen it on heavy duty pick up trucks back in the day. I think it was an option on Dodges. You switched from one battery to the other. I do not remember if they were used parallel for high loads. Batteries were on the left and right of the radiator. If you didn't need an air box, that would be a good place.
Billwill
White River, South Africa
This link above is very good for the discussion on how to connect and switch two batteries...pity that at the end of the thread there is a lot of garbage about how the alternator regulates the voltage.
As far as regards where to mount the second battery...I quit like Bulli's idea in the following link where he mounted it in front of the right/rear wheel arch although I think the finishing off could be better.
www.jeepkj.com/forum/showthread.php?t=49514
