Door Locks Not Working
SKOL
Minnesota
Hello all.
I have a 2004 Liberty. Recently my power locks stopped working. I have to manually unlock/lock doors. My key fob does not do anything. Even when I try to unlock doors using lock/unlock button I get nothing. I cannot open rear hatch as it is locked and there is no spot to unlock it with a key.
I replaced the fuse and every time I test it blows. I am hoping somebody might know what the problem is. A friend told me that the drivers door lock acts as a master for all the locks. He said it latch may need to be replaced???
Has anybody experienced this?
Any thoughts will help. Thank You.
Jeremy-WI
Home
You will likely need to pull door panels off to find a bare wire that is shorting out. I doubt it is the switch
SKOL
Minnesota
After a lot of testing I found the problem. It was the front passenger lock switch. I disconnected it and everything works fine. Connected it and fuse blew every time I tested it.
