Conduit Lift or Level Kit
DJSKJ
California
Looking at adding to my OME setup. Since the Budget Boost is a no-go I am looking at a conduit lift. How much lift can I get out of this? From what I read 3/8" seems about it. However, it does seem fairly easy to do. How many of these nuts do I put in?
Since I have installed my OME springs it has sagged about 1". Seems I could add 1.5" level kit?
I just want to raise the front end.
DJ
3 conduit nuts are 3/8 of an inch thick
so that will give you double that amount of lift
so about 3/4 of an inch
DJSKJ
California
I don't understand how 3 at 3/8" will give me 3/4" of lift? Can I put in 4? From what I have read it seems a fairly simple procedure, no?
The way a IFS front suspension is designed everything you add is doubled. so add 1/4 inch get 1/2 inch of lift
You can add 4 but remember you are pulling the shock up out of the clevis more then.
So while you can most just do 3 to be on the safe side
You could always add a top plate 1/4 inch from JBA or 3/8 inch one from Boiler
I like to do lifts with a 1/4 inch top plate, 3/8 inch clevis, two extra top iso's in the rear with OME 927/948s and when broke in its level and looks good
DJSKJ
California
All right then three it is. I already picked up 6 at Lowes. Seems like a simple procedure; undo the clevis nut, pry it down and slide the rings in. Anything else? I plan to do it this weekend.
Thanks.
DJ
You know they do not actually hold anything they are more for measurement purposes than anything So you could just loosen the clevis, measure before, slide it down remeasure and tighten good
JeepinJarhead03
Petersburg VA
hey.. that's good info... taping the conduit nuts together with electrical tape keeps them together and aligned nice and purty during install :p
no idea what Ry and Jenn's goin on aboot :p
DJSKJ
California
I am trying to pry the clevis down, no luck. Any tricks to this? I saw a post with someone using a sizzor jack?
JeepinJarhead03
Petersburg VA
the slot in the clevis where the bolt went through, gently pry that apart, not much, but just enough to loosen the clevis' grip around the bottom of the shock can
a fat head flat screw driver will work
rockymountain
Spencerville, IN
Put the bolt in backwards as in take it out and put it through the other side. Tighten it just slightly and it will pry the clevis apart. Then you can do your leveling.
DJSKJ
California
I am using a crow bar to try to pry the clevis down and it is not moving. I have the jack stand under the body. Should the jack stand be placed under the lower control arm? Damm it! THis sounds very easy, I must be doing something wrong.
rockymountain
Spencerville, IN
Sometimes u need to use a long 2x4 or something to pry the lower control arm down. Mine isn't that flexible at all and I had to do this when I lifted initially.
