Clutch Safety Switch
acrosland
oxenhope
Car wouldn't start, think its the clutch safety switch that is broken. There are 4 wires on the connection. Any body know which I should bridge to prove its the switch or not?
turblediesel
memberable
Alaska
Other possibilities include ASD relay and ignition switch/shifter interlock or the switch actuator and/or switch itself.
Fuses? Codes? Dash lights?
rahuljones
United Arab Emirates
There is another method you can use to confirm if it is the clutch safety switch. Engaging 4 Low Range overrides the clutch safety switch to start without having to depress the clutch. You can engage 4Lo and see if it starts. If it does start then its the clutch safety, if it doesn't start still then you need check the fuse and relay.
