Changed ****** cooler lines, ****** went into limp mode
Trailrabbit
Canada
Hey guys looking for some advice. Did the ****** cooler lines and new oil pan on my 05 KJ 3.7 (42RLE), everything seemed to go smooth. Pulled out on the highway and it shifted hard into 2nd and stayed there. Check engine light came on and threw 2 codes. P0731, first gear incorrect ratio and P0700 ****** request MIL.
We can only assume when changing the lines some debris may have been stirred up and clogged something up. Pulled the pan and drained the fluid and refilled. went for a good long drive in the woods in low range hoping it might warm up and clear itself up. No go.
What should we try next? I'm thinking a new valve body in the ******. Seems to be a common problem from my searching.
thx for any suggestions
JeepCat
Aran Valley ❄️
Do you use ATF+4?ok
Try this: It has to be at operating temperature, in addition to looking at the level in position N, before doing so, move the gear selector to P / R / N / D / 2 / 1, stay a few seconds in each position, then do the same but in the opposite direction, then go back to N and check the level, remember to apply the parking brake.
Did you replace the trans filter, and use ATF+4 ?
On level ground when driven/warmed up, is the dip stick at the full line?
Trailrabbit
Canada
Do you use ATF+4?ok
we did indeed use Mopar ATF+4 and run through the gears a few times to get the fluid circulating. I did actually use up all my ****** fluid the SECOND time we filled it but the fluid level is alnmost at the full marks. I'll grab another jug and tomorrow and rule that out..
JeepCat
Aran Valley ❄️
Make sure you are on a level surface, re-read the manual, it is always helpful to review these tasks.
Trailrabbit
Canada
Got my hands on some ****** fluid and topped it up. didn't make a difference. Starts off in 1st gear after it's been shut off, rough shift into 2nd and there she stays.
Jeep dealer has star scan scanner that can instruct new fluid, to re learn new shift points.
Otherwise u could remove both battery terminals tape them together for 45 minutes and see if that makes any difference.
Note all previous codes before doing so and note any new codes.
It can take a while for the trans to re learn.
Trailrabbit
Canada
Did you replace the trans filter? Are you certain the trans filter was seated correctly?
just did the ****** fluid not long ago.. filter still like new. Stopped in to a mechanic that works on jeeps a bit more frequently and he said to try a little lucas ****** fix and mentioned one of the plugs we might have bumped when we jacked the motor to do the oil pan(which we did at the same time as the lines). Ill address that stuff tomorrow and report back.
Trailrabbit
Canada
I got er!!! Sprayed some Caig D5 contact enhancer on both input and output speed sensor plugs. Went for a drive and it’s working mint! Tried a bottle of Lucas earlier today as well with no luck but sometimes that stuff takes a while to work... so technically either of those things could have worked. But, Pretty sure one of those plugs was just dirty enough it lost contact while jacking the engine to do the oil pan.
