Can't adjust my side view mirrors all of a sudden
Dave_too
I can't find a listing for a fuse anywhere for them. Anyone know of where the if it exists fuse might be? Since they both went out, I'm thinking potentially the rocker switch on the door might have failed. I'm no electrician. How might I go about trouble shooting this?
Thanks.
Ksat
ny
Unplug the switch on the door and test for power with key on. If you have power, there's probably a problem with the switch. On mine, I found a surface mount fuse on the switch's PCB that had blown.
nmbluept
Rio Rancho, NM
I had that happen on my 2006 Liberty. Started as intermittent then progressed to not working at all. Checked voltage to the switch and determined switch was bad. Got a new one from Rockauto.com for around $30 as I recall. Switch replacement is easy, getting door panel off isn't bad either, just be sure to remove the screws before trying to pop the panel off.
Ksat
ny
Weird. I have an '06, too, and had the same thing happen where at first it worked intermittently then later quit altogether.
If the switch doesn’t get power, check for a broken wire inside the door hinge area, inside that rubber conduit and just inside the door/body. After 10,000 openings and closings of the door, sometimes the wiring there gets fatigued and breaks. I found and repaired this problem on my in-laws’ 04 WJ.
