Camber bolts
WarVet
Texas
What is the semi circular shaped component that holds the LCA camber bolts in place called? Does it come off? How do I remove it?
Only other piece is attached to the LCA,
picture of what you are talking about ??
In case I'm not following you
WarVet
Texas
The horse shoe around the bolt
ridenby
Gold Supporter
Kentucky
I had to cut bolts on mine. If you can get it out you are most fortunate. If you have to cut get the best sawzall and blades you can find,they are beyond hard.
