Blower fan not working
Damotee
Cape York, Australia
Hi all, recently my blower fan stopped working. It doesnt work on any speed. I replaced the blower motor resistor but that did nothing. Im guessing its either the relay or the motor itself has died. Is there a way to work out which it is?
Thanks.
I think the relay is in the power distribution center under the hood. Just switch the blower relay with a like one. Maybe one of the efan relays and see if that helps. If not then probably the motor.
There is also a red 10 amp fuse cavity # 24- PDC blower motor see your owners manual.
There is a set of tests for the blower motor relay found in the Factory service manual as well.
