Bert is in my driveway...won't start...
Just hangin' out.
Dang kids never listen. I told them Bert (2007 KJ 3.7L) was old and tired and deserved to be taken care of and only used around town.
Instead of having me troubleshoot a starting issue, they just threw a new starter in on their own. Good for them...
Then they drove it down to Lincoln, NE an hour a way and lo and behold, Bert wouldn't start.
So the venerable beast got towed to my place and now I gotta troubleshoot.
Has power, but nada action on the starter. Not even a click. Fairly certain what the issue is.(Will follow up on future posts.)
So I'll be posting the process on here as I used to do.
I'm sure I'll have questions and hopefully provide some answers for others.
Fin fun fun. Wrenching on the Original Sciencemobile!
Just hangin' out.
Hmmm.
Electrical is good. Suspect is wrong starter or is improperly torqued. Tough to troubleshoot when you don't know what all happened.
seafish
Or simply "bad" out of the box if it was bought as a reman from a "name your favorite" discount auto parts store.
Did the kiddos save the reciept??
Hec In Omaha
Beaver Lake, Nebraska
Just a thought. Try starting it with the gear selector in Neutral. If it starts then there may be a safety switch at the shifter that needs adjustment. The key should only crank over the starter if the shifter is in Park or Neutral. Worth a try.
Hec
Jeremy-WI
Home
Might be as simple as the solenoid wire isn't connected anymore. I got a bargain on a starter from rockauto that was a Delco reman that they discontinued, got it for $60 after core return and somehow they are still selling the same one for $30 more plus the same core charge
jeepop
Middle Tenneesee
Check for a voltage drop coming off the battery connectors. You might need to cut out some wire and out in a new connector.
Just hangin' out.
Hec
Yeah, no love there.
Just hangin' out.
Truth, but thus far all rings out good.
Check for a broken ignition cylinder pin.
Jeremy-WI
Home
Replacing the starter isn't any fun on these. I replaced the starter on my 96 Chevy K1500 in the parking lot at work without jacking it up
Just hangin' out.
I personally do not like NAPA parts. They are expensive and like to use the cheapest suppliers and re-badge it. Good work verifying it.
I do not like 'em either, but their return policy is pretty good. For reference, most parts dealers do the same thing.
