Are these Liberty's pre-wired for fog lights?
atikovi
Suburban Washington DC
Specifically my 2006 Sport. My grille is cracked and I see a nice chrome one in the junkyard with fog lights. Thought I'd get them too while I was there. I assume I would need the headlight switch as well. Anything else?
REDACTED
If you're lucky, there will be the foglight plug connectors down at the bottom corners when you pull the grille off. In that case, you'll need the turn signal and wiper stalk assembly that has the fog light switch as well as a relay. If you don't have the plug connectors, you'll need to mess with the wiring
