are spacers bad for the suspension?
themadness
USA
i like the stance it gives but will they damage the wheels, tires, axles, etc? any other way to get a more aggressive look?
Not really but now you have 40 lugnuts to worry about instead of 20,oh and they are illegal in most area's anyways.
Better solution is to get rims with less back spacing,same effect but 20 less lugnuts to worry about.
Dmut
one of xUSSR republics
if you going to keep rims with the same offset, then spacers will create more stress on hubs, because offset (and leverage) is virtually insreased.
if you going to use rims with smaller offset, then overall leverage will be the same, but then you will lose main point of spacers - wide wheel spacing and aggressive look of vehicle.
also, some poor quality spacers could unbalance your wheels.
basically, spacers are only good if you want to use a rims with different lug pattern.
I agree with TJ - if you really want a wider wheels spacing, then change a rims. hubs will get more stress, but you will look "aggressive" ))
There are also laws here about tires sticking out past the fender wells.
Ryan & Jen use spidertrax http://www.spidertrax.com/products/2002-Up-Liberty-KJ-KKand has had no ill effect on the original hubs at 150k miles.
You will get more stability and wider stance, but I agree better off to find new BS rims without spacers, and possibly longer studds may be required then.
Staff online
