Another Weep Jeep!
Discussion in 'KJ General Discussion' started by LibertyTC, Feb 8, 2016.
  1. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,300
    463
    Jeep's can beep, creep, even go do deep, but they sometimes like to WEEP! :icon_lol:
    A first I thought this was a power steering leak or weep....
    [​IMG]
    Hmmm...that looks like oil to me, not ATF+4 from power steering...
    Oh well..out comes the LPS, no touch, just spray.. guaranteed super cleaner!
    [​IMG]
    Cleaned area quick & should be able to get a better idea soon...
    Valve cover gasket leak?
    [​IMG]
    Where does your jeep weep? Transfer case like me too?
  2. JeepJeepster
    JeepJeepster Full Access Member
    8,438
    Dec 15, 2004
    So far the only seals NOT leaking on my KJ are the 4 axle seals. Everything else leaks... Pinions, tcase, front main, rear main, valve covers, got it all.
    Just changed the tranny fluid or the pan would be leaking also. Seems to be holding for now though.
  3. tommudd
    tommudd Moderator Staff Member Moderator
    18,102
    521
    04 high pressure line for the PS weeps just a bit, nothing to worry about and ay 220,000 miles she is allowed to
    The 03 and 05 have no leaks at all, ( well until tomorrow morning now that I've mentioned that they don't
  4. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,588
    138
    Quite a few very minor leaks. I'll find out soon if my tranny pressure sensor still leaks now that I've changed the o-rings. That was the only one that annoyed me since it would make it to the ground. PS hose had weeped since I bought this thing back in 07. Hasn't gotten any worse and never have to add fluid.
  5. sota
    sota Full Access Member
    1,566
    174
    dude... my one car thinks it's a news media outlet: if it bleeds it leads.
    either that it thinks it's british. (if there ain't no oil under 'em, there ain't no oil in 'em!) :D
  6. dude1116
    dude1116 Full Access Member
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Fairly certain my rear seal is leaking, I fixed my leaking valve covers, power steering hoses are weeping and rack is leaking, right rear axle seal weeps, trans pan weeps...
    At least weeping stops once the weep is clogged with fluid. Doesn't look pretty but it means I don't have to deal with it quite yet. What's killing me is the rear seal leak and the power steering leak.
  7. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,739
    114
    I think my rear main is weepy. Has been since it was 4 years old. I think the high pressure PS line is bit damp, don't need to add fluid for years. I think that's it, probably jinxed it. :D
  8. Dave
    Dave Administrator Administrator Moderator
    15,590
    It's 20 degrees here and too cold to look for weeps. I don't see any "weepy spots" in the snow. If it gets any colder I will be the weeper......LOL
  9. twowings
    twowings Full Access Member
    802
    Nov 23, 2014
    Tulsa, OK
    Dry as a bone except for the aforementioned PS hose...I'm just really lucky so far at 97,900 miles...
  10. JasonJ
    JasonJ Full Access Member
    1,521
    43
    Jul 8, 2013
    Michigan
    Power steering pressure line is damp.. fluid level hasnt dropped, so no harm. Maybe minor seepage from something in the area of the rear main/front trans pump seal. It isn't forming droplets so, again, no harm.
    My right side valve cover gasket LEAKS. I have a new gasket set.. just I crashed the Jeep before I could put them on. It's like 20 degrees outside, who am I kidding? I aint putting those gaskets on til spring!
  11. twowings
    802
    Nov 23, 2014
    Tulsa, OK
    If you get a warm day, it's not that bad of a job...if the driver side gasket isn't leaking, leave changing it until Speedo season...
  12. ArtO
    ArtO Full Access Member
    30
    Jun 18, 2015
    Weedsport
    [​IMG][/IMG]
  13. profdlp
    profdlp On The Ledge
    5,004
    296
    No leaks (knock wood). And the best part is that my Jeep has not been leaking money lately. My A/C compressor would have been a hit if I didn't have the warranty, though.
  14. JasonJ
    1,521
    43
    Jul 8, 2013
    Michigan
    Mine just had its A/C bearing crap out. Seized up just about. Pulled that compressor out of the way, a little mechanic's wire to hold it up and away from the new, shorter belt.... voila! Leave til spring or summer when I feel like addressing it.
    Speedo season? you clearly have not seen my gut... it would hide the top half of said speedo. Let's go with motorcycle season... when I drive the Jeep less anyhow. :) Far less of a disturbing visual on that one.
  15. JeepJeepster
    8,438
    Dec 15, 2004
    Ohh my power steering line was weeping pretty good. Changed it out, pump has whined ever since...
  16. colorado76
    colorado76 Full Access Member
    849
    May 16, 2011
    Rocky Mountain High
    My power steering line has always weeped, never had to add much fluid to it. Gets worst when it's cold outside really notice it on the ground. But summer never really notice the weeping on the ground it's always on the line.
