Accidented Liberty won`t start
DaleD
Quebec, Canada
I had an accident and now my Liberty will turn over but won't start. It seems as thought the fuel pump has been shut off and won't restart. Any ideas? I was hit in the rear right corner spun around and flipped on the drivers side.
70AnvKK
Phoenix, AZ
Did your air bags deploy? If so, that will shut down the fuel delivery system. Also check the fuses in the PDC under the hood. I believe it is #14 that runs the ignition system.
renegade 04
Albany New York
if your air bags went off then the auto shutdown relay has be activated and you jeep will not start. If that is the case you will need to get it towed to a dealer and have them reset the airbag modules.
