cajunrebel
My AC clutch bit the big one last week and I had to pull it and run a smaller belt. I dont have the cash to replace the compressor much less the 10 million other things that the parts stores want you to replace in order to warranty your compressor. I have found a rebuild kit for the clutch on fleabay and am considering it. It however does not include the pulley, just the clutch assy, coil and bearing. Should I see about having a shop clean the surface of my current pulley up and reuse it or should I find a pulley. Mine is fairly worn and in need of a very good cleaning. I can do the rig on the clutch easily (I am trained to rig aircraft landing gear) so the whole install is not a big deal, just need to know if its wort it to reuse that pulley.
