Since it's now a sticky with my name on it I'll have to add more:emotions34:
Here is a start my sources are improving, but I'll later spend time on formatting etc,,,
Disclaimer Some of this covers years other than 2006 but all of this covers 2006. It is incidental that other years are listed and they would have other TSB's and recalls that don't apply to the 2006 and would not be in this list. Some of this is copied and pasted and Some is manually entered. It will have some small errors and is meant to be a guidline to understanding some of the Chrysler cork's. Many of these cover other Chrysler vehicles that I left out due to space.
I skipped some that were available because they have been covered extensivley on this site (window fix) although below is a track fix for both front and rear windows that may help not break the poor quality window parts. A good DIY for the non warranted window problem years. Some others skipped were tech only how to use the DRB111 computer and when to total a transmission vs just replace it kind of stuff.
CUSTOMER SATISFACTION NOTE: transmission 545RFE
October, 2005 2006 models only - A/T 545RFE Cooler Return Filter Replacement
Dealer Service Instructions for:
Customer Satisfaction Notification E16
Transmission Cooler Return Filter
Effective immediately, all repairs on involved vehicles are to be performed according to this notification. Service Bulletin # 21-016-05 is cancelled for 2006 vehicles. Those vehicles that have already had this repair performed, as determined by our warranty records, have been excluded from this notification.
Subject
The transmission on about 17,200 of the above vehicles may experience a delayed engagement when the shifter is placed into gear after the engine has been off for more than 12 hours.
RECALL BLOWER MOTOR FIRE
May 2007
Safety Recall G03
Blower Motor
Models
2006 - 2007 (KJ) Jeep(R) Liberty
NOTE : This recall applies only to the above vehicles built through August 15, 2006 (MDH 081523).
IMPORTANT : Many of the vehicles within the above build period have already been inspected or repaired and, therefore, have been excluded from this recall.
IMPORTANT : Some of the involved vehicles may be in dealer new vehicle inventory. Federal law requires you to complete this recall service on these vehicles before retail delivery. Dealers should also consider this requirement to apply to used vehicle inventory and should perform this recall on vehicles in for service.
Involved vehicles can be determined by using the VIP inquiry process.
Subject
The blower motor on about 149,000 of the above vehicles may overheat and cause an interior fire under certain operating conditions.
Repair
The blower motor must be replaced.
RECALL 2002-2006 LOWER BALL JOINTS
September 2006
Safety Recall No. F23 -- Lower Ball Joints
Effective immediately, this recall (Safety Recall F23) cancels and supersedes Safety Recall C36 Lower Ball Joints. Please remove and discard from your files all copies of Safety Recall C36 (dated December 2003). All vehicles involved in Recall C36, whether completed or not, must have this recall performed.
Models
2002-2006 (KJ) Jeep(R) Liberty
NOTE: This recall applies only to the above vehicles built through March 15, 2006 (MDH 031510).
IMPORTANT : Some of the involved vehicles may be in dealer new vehicle inventory. Federal law requires you to stop sale and complete this recall service on these vehicles before retail delivery. Dealers should also consider this requirement to apply to used vehicle inventory and should perform this recall on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
Water may enter into the front suspension lower ball joints on about 820,000 of the above vehicles. This can cause the ball joint to corrode and separate. Ball joint separation can result in a loss of steering control and could cause a crash without prior warning.
Repair
Both front suspension lower ball joints must be replaced.
NOTE : Ball joint heat shields must also be installed on 2002 and 2003 modelyear vehicles that did not have Safety Recall C36 performed.
IMPORTANT : Owners involved in this recall will be notified in phases by model year (oldest-to-newest) based on parts availability.
RECALL DOOR LATCH
Recall 06V072000: Possible R/H Front Door Latch Defect
MAKE/MODELS: MODEL/BUILD YEARS:
Jeep/Liberty 2006
MANUFACTURER: DaimlerChrysler Corporation
NHTSA CAMPAIGN ID NUMBER: 06V072000 MFG'S REPORT DATE: March 07, 2006
COMPONENT: Latches/Locks/Linkages: Doors: Latch
POTENTIAL NUMBER OF UNITS AFFECTED: 27
SUMMARY:
Certain sport utility vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 206, "Door Locks and Door Retention Components." An incorrect right front door latch reinforcement plate may have been installed which may cause the secondary door latch to become inoperative.
CONSEQUENCE:
This increases the possibility of a door becoming forced open and an unbelted passenger being ejected during certain crash conditions.
REMEDY:
Dealers will inspect the latch assembly and replace the right front door latch reinforcement plate free of charge. The recall began on March 13, 2006. Owners may contact DaimlerChrysler at 1-800-853-1403.
NOTES:
DaimlerChrysler Recall No. F11. Customers may also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to
http://www.safercar.gov.
RECALL 42RLE TRANSMISSION
November, 2005
Safety Recall E14
Transmission Cup Plug Bracket
Models
2005-2006 (KJ) Jeep(R) Liberty
NOTE : This recall applies only to the above vehicles equipped with a 42RLE automatic transmission (sales code DG6) and a transmission build date code from TK2454 through TK1235. Many of the vehicles built within this transmission date range were repaired before shipment to dealers and therefore have been excluded from this recall.
IMPORTANT : Some of the involved vehicles may be in dealer new vehicle inventory. Federal law requires you to complete this recall service on these vehicles before retail delivery. Dealers should also consider this requirement to apply to used vehicle inventory and should perform this recall on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
The cup plug that retains the automatic transmission parking pawl anchor shaft on about 253,000 of the above vehicles may be improperly installed. This could allow the park pawl anchor shaft to move out of position and prevent park engagement. If this occurs and the parking brake is not applied, the vehicle could roll away and cause an accident without warning.
Repair
A transmission cup plug bracket must be installed.
