04 Liberty inner rocker replacement?
Harry1970
Westfield, MA
I'm sure someone has tackled this issue before. It an 04 Liberty in need of rocker replacement. I am in process of replacing the inner and outer rocker on drivers side but behind the rocker that kinda ties into the floor that piece is rotted out. Haven't seen any replacement for that. Is there a replacement or just fab some sheetmetal?
Also I coated everything with Ospho any other suggestions for slowing the rust down?
Thanks
Harry
Harry1970
Westfield, MA
Yeah, Massachusetts has been brutal on the Liberty, thanks for the link I have 03 I could never find the 04 one.
I want to try the Eastwood's non hardening frame rail coating. The ospho is just to slow what rust is there down.
Passengers side of the libby no where near as bad. Just outer rocker replacement.
Thanks
Harry
I would be interested to know how the frame rail coating work out.
How long is dry time, and how thick it is.
Shane Giggie
Mine is as bad as yours or worse, I need to get it fixed this spring. But it works good and I love her and it's worth fixing.
308slegs
Roaring Spring, PA
Hi Harry. I just stumbled onto your post as I am dealing with the same problem. How did you make out on this project? What did you end up using to replace them?
I had the same, just got a sheet metal guy to fold me some new ones out of 2mm steel.
Note the handy temporary work bench / next years kindling :)
Staff online
