02 sensor replacement help!!
bmrrwolfe
North Olmsted, OH
I got a p0137 and p0138 so i got a new after cat 02 sensor and am in the process of replacing it but i cannot get the electrical connector to disconnect!!
Anything i can do to that to come off??
OHIO04KJ
Stow, Ohio
Mine was a pain in the **** also. There is a little clip that holds them together, squeeze and pull brother;)
OHIO04KJ
Stow, Ohio
Not sure! Is there enough left to splice it back together?
BTW, did it come apart easy now that your holding it?
bmrrwolfe
North Olmsted, OH
now that im holding it i still can't get it apart!
three pins came out of the harness so i could i get those 3 back in and i broke one pin...
so there maybe a chance of saving it, but im getting a wiring diagram for the 02 sensors printed out from my dads buddy at the dealership so we shall see what we can do with it....
ridenby
Gold Supporter
Kentucky
There is a universal 02 sensor made to splice in the harness.
bmrrwolfe
North Olmsted, OH
Well my main issue is the wires coming out of the main harness aren't marked and 2 are identical black... im going to try to reuse the connector and shove the pins back in the harness and see if that works. :(
bmrrwolfe
North Olmsted, OH
Alright i got the pins sodered back on the connector back on and drove it to work (only about 2 miles) and seemed to run normal, i still haven't gotten to reset it but i will when i get home tonight!
