I've been searching high and low for a solution and was hoping you guys could help since the dealership had no idea what I'm asking them.
Got a 2002 3.7liter 5 speed man trans 2WD. Had it for about a month now and all of a sudden the clutch starts acting kind of funny. The clutch normally grabbed when I released the pedal almost all the way out. I went to go take off in first and it immediately grabbed right at the floor. So I figured it wasn't disengaging all the way but it only does this in first. When I'm in second the clutch grabbed where it normally did. The grab zone on the pedal is almost moving around on me because I was at a light in 1st with the clutch in and all of a sudden the car starts to move and the pedal goes soft and I'm driving off, but then the pedal is normal again once I'm moving.
I decided to check the hydraulic fluid level, and come to find no spot to add, and from what I've gathered so far it's a sealed system and supposedly can't be bled. I couldn't find any leaks and the clutch isn't slipping. Any thoughts on this mess? Thanks.
