Interior lights
Tinaweena
Kitchener ON Canada
Ok...so when I turn the lights on at night, the cluster all lights up like it's supposed to. However, the umm, how should I say it....letters "P R N D" on the gear shift thingy...don't like up. Are they supposed to? I'd like to know as soon as possible so I can get them to fix that when I take it back in for tints tomorrow.
Thanks a bunch, sorry for all the questions....I'm new.
Jtimpe
Lights
I just went outside to check mine. Unfortunately the sun is shining very birght today and I could not tell for sure but I think they do light up. It certainly makes sense that they should. Hope this helps.
Tinaweena
Kitchener ON Canada
Thanks for trying.....
If there is anybody out there with a garage that could check, I would totally appreciate it. I would understand them not lighting up if there was something to indicated what gear you were in on the instrument cluster, but there isn't! Argh
Bennett
Active Member
Green Bay
I know they light up, since I had to replace the bulb in there once already.
It's a ubber tiny bulb, smallest I've ever seen. To replace it I think all I had to do was pop off the cover and then the bulb simple twists out after you get your fingers on it.
Bennett
Tinaweena
Kitchener ON Canada
Bennett
ok, thanks so much. I won't be changing it tho...considering I just picked it up. When it goes in for tints, they can take care of it!
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Tina, the satisfaction of working on your own Jeep is great, lol... you should do it. \:D/
btw, yes, they light up.
Bad pic, but you get the point.
Tinaweena
Kitchener ON Canada
Thanks for the pic...I see they are illuminated. I also know the satusfaction of working on a car...I did a TON of stuff on the old car (nothing on it worked :( like it was supposed too). I will do my own stuff, maybe after I've had it a week or so hahah But since it's a day old to me, I feel like everything on it should be working, I paid enough for it. Thanks for all the info and quick replies guys....good little forum you've got here.
