HOW TO: Install front D-Rings
Bennett
Active Member
Green Bay
Pick up a couple of trailer hitch bars. I found these for $1 because the hole for the pin was the wrong size and the store wanted to get rid of them.
Remove the front bumper and then remove the access cap for the bolts.
Mark and drill the mounting holes. You may need to open the hole for the D-ring slightly.
Pick up some strong bolts. Note longer, stronger and thicker 1/2"
Reinstall the bumper. A bit of cutting will be necessary
Thats it.....
Match the rear one also \\:D/
TRAILN
misterzero
Any way we can get an update on those dead photos?
misterzero
Well, I meant new photos. I wanted to do this on mine, but half the photos are dead. Thanks for the update though. Gives me more reason to do it. O:)
TRAILN
Toronto, CANADA
Thanks Bennett
I'll see if I can find them. They were on my old PC, I know I saved them its just a matter of finding them
Wow Bennett....Those look awsome.....I'm jelous. All I have is the OEM towhooks up front.
riptricket
OKLAHOMA
what kinda tow arms are those? i want to do this mod to my 05 renegade, but i do not want to cut the fascia crap.
Gris
Scranton, PA
they're 1" (class II ?) arms with a 3.5 inch drop. The drop is what makes then come out the hole instead of cutting.
I have a few more of those shackles if you are interested in em. PM me.
csukoh78
Nunya
I like it. I would do it if I didnt have the mopar brush guard
Gris
Scranton, PA
yup. drilled a couple holes through each so they line up with the holes in the frame where you mount the stock tow hooks. Then just bolt them up.
o8k
how the frick did you drill through that super thick tow hitch? ive been looking for a D-ring place but no luck so far =(
