kjweston
I'm not sure what the EVAP does and what it could do if it was leaking.. can someone inform me? Thanks, Chase
Don't take this for gospel Chase, I'm sure someone will be along to correct me.
EVAP is for vapour recovery. Keeps our gross polluters from polluting even more. An EVAP leak or malfunction will pop codes, OBDII P0440 thru P0459 are reserved for EVAP system operation.
Helped?
It will effect your mpg's,how much depends on the size of the leak.If the gas vapors leak out uncontrolled you are wasting gas,just letting it disappear before burning.Just remember liquid gas does not burn or is combustable,it's the vapors that are highly flammable.If you take care of the problem now it will be cheaper then doing it down the road and then you can get rid of the check engine light so when you have another issue you will know.
used 1/2" on mine. Snug fit, no more 0442 or 0455
