Water pump going... suggestions?
jnaut
Seattle
Got a water pump on the downward spiral. Any recommendations on brands? I see there are the basic OEM replacements, and then I see a few 'premium' brands (for more greenbacks, natch). Just curious what everyone thinks... should I stick with OEM or get a premium?
calbear
Turkey
OEM should be made by Kager(33-0892) or Airtex(1725). maybe you can find them cheaper outside the dealer.
jnaut
Seattle
The innernets sells the OEM replacements in the range of $75-$85 or so. I recall seeing a premium brand (I could find it if I weren't so lazy today) at over $100.
ridenby
Gold Supporter
Kentucky
Close Refresh Save My Place Print Send these listings to a friend Filter These Part Listings Related Parts
2002 JEEP LIBERTY SPORT 3.7L 226cid V6 FI (K) : Cooling System : Water Pump Price Core Total Advice
HYTEC Part # 317061 More Info (Only 1 Remaining)
$43.79 $0.00 $43.79
Add to Cart
CARDONE SELECT Part # 5533418 More Info {New; Includes Gasket}
Part Image
$46.79 $0.00 $46.79
Add to Cart
GATES Part # 43263 {Water Pump (Standard); Cast Aluminum, Standard Rotation *May Not Include Pulley*}
$47.79 $0.00 $47.79
Add to Cart
A-1 CARDONE Part # 58572 More Info {Reman. Includes Gasket}
Part Image
$36.99 $15.00 $51.99
Add to Cart
ACDELCO Part # 252813 More Info {#89036348}
PUMP KIT,WAT
Part Image
$54.79 $0.00 $54.79
Add to Cart
BOSCH Part # 98209 More Info
OE Replacement
Part Image
$56.79 $0.00 $56.79
Add to Cart
ROCK PRODUCTS Part # WP1100 {Includes Gasket}
SOHC
$57.79 $0.00 $57.79
Add to Cart
Rockauto.com
jnaut
Seattle
Thank you, Ridenby. I've been checking a lot of the other websites, including NAPA Online, most started around $70(+) for new-- $45 or so for remanufactured, but I ain't goin rmfd for a water pump. It's not like it's a transmission where I might save $1500 bucks. I might go for that Bosch for $57.
Spidey
Charlotte, NC
I picked up a new one from O'reilly's for $55~ with a limited lifetime warranty, whatever that means exactly. So far so good, not that a water pump is really rocket science.
04Liberty
MD
Whichever one you get, make sure it's the right one, the 3.7's used to share water pump with the 4.7's, then Chrysler came out with a TSB specifying a different water pump.
jnaut
Seattle
Hmm, ok, my normal process would be to go to website, and during vehicle selection process put in '04 Liberty Sport, 3.7 and then choose from the options that come up for Water Pump. Am I not guaranteed to get the right one going that route?
ridenby
Gold Supporter
Kentucky
Same process I use on web,or at parts house. So far so good.
Porkchop
Troy Mi
Don't you have to flush and use new HOAT coolent when changing the water pump too ? Oh and check the rad cap
jnaut
Seattle
My understanding is that if you retain all the coolant and it looks good, no flush is necessary. I'll probably do it just to do it, though. The dealer did all my service through 70k miles (5 years) and honestly, I'm not sure what they did beyond the oil changes regardless of what the book was calling for. I do know they rotated my tires because I had the air-wrench overtightened lug nuts with lost covers to prove it. But on the little stuff? Not sure. I pulled out my spark plugs at 73k and they looked very, very original with gaps that would make a bad mechanic blush...
