Trans fluid
marky38
michigan
Hi there...the Jeep has 193k..trans shifts fine and seems normal..we bought it a few years ago and never messed with the trans...what do you think about the color/condition of this fluid?..I used a white zip tie to check it..thanks
Fluid appears possibly a bit thin, not as red as expected. jeep uses Atf+4.
Used a white zip tie to check it? Where's the dipstick? What year is your jeep?
It's easier to see the color of fluid when wiped onto a white paper towel.
marky38
michigan
marky38
michigan
It's an 07 no dipstick...good idea about the paper towel..I'll up date it tommorow.. I'm thinking about sucking out what I can through the dipstick tube and adding new fluid..I really don't want to drop the pan and such
jp7794
It is not that bad of a job but it is messy. I was never a big fan of pumping out fluid. It really needs to drip out to fully drain everything from the transmission internal components. Might want to invest in some foil until you can get a dipstick. :)
LONGJEEPOWNER
NE Pa.
A friend of mine at the ****** shop said you can use your oil dipstick to check the ****** fluid. Clean it off and then check ****** fluid. The level should be 1 1/2" above the full mark on stick.
marky38
michigan
T
The 07 came with a screw on plug instead of a dipstick
Yup no dipstick on the 07's. Good ole Jeep, they want to force dealer servicing.
IDK the current status/availability of installing a tube/ new dipstick.
The main reason for dropping the pan is to also change the inside filter as well.
marky38
michigan
jp7794
Far from an expert, but it doesn't look 193K old so it has been changed sometime. Can't smell it, but I have seen much worse.
If it is smelling burnt I would change it, do the filter as well.
I installed a PML 42RLE machined aluminum pan, with drain plug.
My fluid gets drained every 30K miles & at 60k is when I do the filter inside.
If you ever get a trans temp light, change it asap.
turblediesel
memberable
Alaska
Book says something about removing one of the central pan screws in the back which drains most of the fluid. Then loosen all along the back and you have more control of where it all goes. Better than the everywhere-all-at-once method. Black silicon gasket maker is the gasket. You can buy a gasket too if you want.
