Toggle switches
Zero402
South Florida
Where did you guys mount your toggle switch for whatever accessories you added? I have a 3 panel switch but finding it hard to find a flat surface on the dash. Pics would be great
Ive mounted them where the Renegade overhead light switch was, also in center console drivers side of the shifter etc
Then with a 3 panel in the little storage area below the radio
Doing10to20
I mounted mine driver side of the steering colum right under it the panel comes out for easy install access
Doing10to20
Did you use a panel, or are you using single switches?
Did you have to remove the metal knee support?
I used a 3 toggle panel and I didnt remove anything, I worked the wiring around any metal and only had to cut out a square big enough to mount the switch panel in the plastic..I can take pictures for you tomorrow if you like...I think I posted it on what did you do today section tho
Zero402
South Florida
I went thru your posts in the "What you doing" section and found the photo. Thanks
Doing10to20
I'm sure you have more patience and a better eye for detail than I do so it will prob look better than mine
mercdudecbr600
I. Mounted 2 rockers (locker) horizontally in sequence to the left of column in the small middle dash trim piece. Easily removable and looks oem
