steel brake lines-do it or don't?
calbear
Turkey
I relocated the rear brake lines on my 2006 kj with esp while doing the 2.5" lift. However now everytime I flex to the limit I get out to check if I tore the rear lines.
look at the brake line here
While browsing on Jeepinbyal website I saw these extended steel brake lines. Has anybody use these on a 2006 with abs and esp?
I want to know if they are worth 300 bucks. It's gonna be either these or the GDE tune for November's mod of the month spending.
http://jeepinbyal.com/prod-SS_brake_hose_kit_for_2_5__lift-7.aspx
They are worth it,besides getting the longer lines the actual braided hose is replaceable(and cheap to) from ClasicTube.com.Sadly the blocks are the pricey part.Plus you will get a better brake pedal feel as the braided lines do not flex like the OE rubber lines do,and they palinly will last longer and will take more abuse before failing unlike the OE rubber lines.All my flex lines for my brakes came from classictube.com,same place that makes the lines in the link,high quality and DOT approved.
