Roof mounted running/marker lights, is it possible?
JeepCoMJ
SE WI
the last positioning is literally the ony one that looks good.
But I'd prefer the light bar, or to do nothing but delete the roof rails.
TheBlueKJ
South Jersey
ive never thought of this on my kj, but it would look nice if done right. im still trying to decide on mounting the led light bars under the dash for floor lights.
I've actually done this and it brightens it up ALOT
VAhlene
Castle Rock, CO
Installed, some may like it others may not:bleh:, I understand this. I personally dig it :happy107:
Counting My Blessings
I like them. I'll bet a lot of folks slow down when they see you coming up behind them, though. :dogpile:
jschenck
Toccoa, Georgia
OP, how to write up please? Had this thought about a year ago and then scratched it. Also, parts and price list?
VAhlene
Castle Rock, CO
I will try an do a write up here soon, honestly I just followed the instructions that came in the package. Got a pack of 5 lights and a switch for $19.95 from local auto parts store. You will also need to remove the headliner partially up front as you have to drill and mount them. The part that took the longest was getting them set exactly where I wanted them, lots of measuring. They came with a template you trace once you have them placed where you like them, just drill and screw them on. I also used some RVT sealant just to ensure no leaks.
CzarKJ
Townsend, MA
I am really considering this! I really like the look. How was the under the dash wiring?
VAhlene
Castle Rock, CO
It's not bad at all, just a power lead a neutral and ground with a standard toggle switch, got the whole kit for $20 at local auto store have had no issues thus far.
CzarKJ
Townsend, MA
I was thinking hook it up to the running/parked lights. I really don't want another switch.
tlrtucker
Denver
Looks slick!
I've been thinking a lot about doing the same with the new smoked Denali HD marker lights...couldn't find a better pic
CalcityRenegade
Calgary
On my Sierra HD yes, On my Liberty no but I also have the light bar which I seem to use on a daily basis lol.
VAhlene
Castle Rock, CO
I smoked the lenses with VHT nightshade, I was having issues hooking up to running/parked lights, kept blowing the fuse when I turned everything on so I just put them on a seperate circuit and they are happier that way!
CzarKJ
Townsend, MA
Well I was going to have a separate power source for the lights but use a relay connected to the parking light. That way when the parking lights are on it turns the relay. Am I thinking correctly?
CzarKJ
Townsend, MA
I am thinking fuse tap to slot #7 (drivers side front/rear park light and license plate light). While I don't like the idea of a fuse tap this makes it much much easier for me than digging for wires in my dash. Just connect that to a relay with separate power and I should be good to go. If this is too much power for the circuit I will probably change out the lights to LEDs.
CzarKJ
Townsend, MA
Edit: forgot to mention they are hooked up to the parking lights/headlights through a relay
