the_dealer
I've been running a Sundown E10d4, which was on a Sound Ordinance/Crutchfield 1350m. I put the amp into the wife's ride and was running a brx1200.1. I had been toying with the idea of running an 8" sub to get some storage room back. I ordered an American Bass XD844, and swapped amps with the wife. I'm building a box and will run a single and see how I like it. I'll more then likely add a second, and will be changing amps either way. So here's the build. I'm building it a little on the large side to make up for lack of power. .97 cuft [email protected], 10.5x1.5 port
I went to home depot this morning and picked up 2 small sheets of 3/4" MDF. I usually get the full size sheets but wouldn't have any help today.
Also, I only have access to my grandpa's old ass table saw. I used it to build my E10 box and it was horrible. The fence wouldn't stay tight and locked in crooked. I was able to adapt and overcome like a boss. See my pimp roller stand to hold the cut end up?
First cut, this was the height for all of the walls and the port. So far so good.
...and I ran out of wood. The picture makes them look cut uneven, but they turned out perfect. Here's all the cuts except the bottom and top pieces. I'll have to pick up another small sheet tomorrow to finish the cuts. Hopefully I'll be able to start putting this thing together. Im extremely haooy with it so far, and its half as wide as my current box. Btw the dimensions of the box are 16w x 12h x 17d
Sent from my SAMSUNG-SGH-I537 using Tapatalk
