OK, so WTH does it mean?
ElCheapo
Erie PA
Got a P0513 code in my odometer, this is what it says, what does it mean?
Is it simply from when I made a couple spare non-electronic keys?
P0513-invalid Skim Key .
P0513-skim System Invalid Key Code Received
P0513-skim System Read Access To Eeprom Failure.
P0513-skim System Write Access Toeeprom Failure.
P0513-skim System Write Access To Eeprom Failure.
ElCheapo
Erie PA
OK thanks. It runs fine, no problems, I just check the codes once in a while.
Billwill
White River, South Africa
Definitely complaining about the non-chipped keys!:icon_smile:
ElCheapo
Erie PA
Did you use any of them to start it?
Possibly. I mostly made them for extra's for the door, but might have tried it in the ignition too.
I guess I can just unhook the negative battery cable and it will reset?
I did the exact same thing on a different chrysler product. same result too... angry "code" about the non-chipped key that went away after I pulled the master fuse for a while.
I was once told though, be careful when using your non-chipped copy in the ignition. Supposedly you can actually piss off the SKIM system enough that it'll semi-permanently shut down the car until the dealer "unlocks" it. I don't know if it's true or not but i certainly wasn't going to experiment to find out. :D In the door(s) you should be fine.
ElCheapo
Erie PA
Good to know! I only tried them to see if it would work in an emergency.
