no power
9maddog
United states
my 2007 jeep liberty ,has no power lights any sign of life.
took the battery out to put in new upper control arm a few days ago, now i put the battery back i have nothing.,anyone have any tips
Billwill
White River, South Africa
Have the battery tested or swap it out for a new one.
I presume you connected it back with the correct polarity!;)
Check all the fuses under the hood and on the inside fuse panel.
You will need a Multi-meter to check voltage across the battery and to trace where it may be going missing.
JasonJ
Michigan
Do you have a DIGITAL voltmeter? Can you verify power at the battery cables/terminals while connected?
Can't tell you what to fix because we don't know what you did... .clearly something either broken or disconnected while you were doing the job. Just verify power is where it should be, cables and all wires are properly connected and tight, no open shorts...
9maddog
United states
Cleaned the ends and had a few attempts putting the battery back,I didn't have my multimeter with me,took the battery to advance auto they tested had 5.81 volts measured 0 F2F ,computer came up to replace battery,I don't know if that would make my car totally dead .
9maddog
United states
I dont.see anything broken ,I have taken out barriers before ,this weird ,like I said I am doing front end work ,had to take out the battery and fuse box to get to the upper control arm,but all the wiring looks just like before I touch it,getting another Sears battery,they said it's still under the warranty,put it in when I get home ,see what happens .
plus i.am still finishing the drivers side front end before I get to the passengers
9maddog
United states
got the new battery from sears,it was still under warranty ,put it in ,everything came up like normal,tested the new battery over 12 volts and tested the positive end and it was reading over zero and over twelve volts when key turned on
JasonJ
Michigan
So the battery was bad/dead?
A voltmeter would have shown this without as much confusion, and probably could have been charged. The next question is why did it fail or deplete it's voltage in the time it took you to replace the one control arm?
9maddog
United states
Didn't have my meter on hand ,plus Sears tested and gave me another battery,they told me it was beyond rechargeable,it was two years old .
Never had a battery that had no sign of life ,when I get home I'll try to see if I did any thing to cause it to dye
