No Low Beams
Gwraalstad
Update on the, NO LOW BEAM ISSUE. I finally found the problem but need suggestions on how to fix it. I pulled the Low beam relay and tested it. It was ok so I checked to see if there was power to the relay. Removed the relay and connected a spaded wire to # 1 terminal, no luck. Then did the same to # 2 terminal, no luck. So, I removed the cover on the relay and wrapped a rubber band around the arm/contact and the coil mounting bracket closing the contact as when the coil would do when got power from the Multifunction (MF) Switch. I plugged the relay back in and, WALLA, the low beam head lights worked. But the low beam lights do not turn off when you turn off the MF switch. Now here is where I'm at. I have an in-depth repair manual that I got online, extremely detailed but the downside is that it does not have a one page/picture of a complete wiring diagram showing all the wires, connectors, and switches so you can trace a circuit from its end back to the point of origin where power is initially applied through a switch and the contact position on that switch. ie. MF Switch. A good MF Switch is only $66, but if there is something less expensive or there is a connection between the MF Switch and the relay that I have missed, please let me know. If anyone can steer me in the direction of a good all-in-one wiring diagram it would be greatly appreciated.
Repl
