Need help with rear door seals...
JeepLibertyKK
I need help in identifying the part numbers and any possible after-market auto parts supplier for the rear door seals of my 2012 Jeep Liberty Sport. I just discovered that both are heavily damaged, though we don't use the rear seat much nor open the rear doors much.
Replacement looks like it's easy to do, just need help with a source.
Thank you
nchorselover55
Cedar Point, NC
Thank you
Bumping this, I need the same seal on the driver side........
JeepLibertyKK
Part number is JEEP 5112244AD. Same part number for both sides of the chassis. This part number is for the seal on the body-side of the chassis only, not the door side. There are two seals in total, but in my case, only the one on the chassis side wore through.
From eBay seller newsmyrnacjd1:
"There is one weather strip mounted on the door itself and one weather strip mounted on the body. Both work together to seal the rear door. Part number for the door mounted weather strip is 5112250AB for the right side and 5112251AB for the left hand side. Part number for body mounted weather strip is 5112244AD for the right side and 5112244AD for the left side as well. Same number for both sides..."
