my KJ is corroding away lol
Midgear
Mcalester, OK
I'm standing next to my KJ, passenger side, bullshittin' with one of my friends. we're just chattin' it up, talking about anything that comes to mind.
I reach over and give my antenna a little wiggle.. not a violent shake, just a bit of a wiggle, the top shook back and forth mabey 3-4 inches. IT SNAPPED OFF.
I cannot believe how easily it broke off.. I thought "how in the hell does this thing recieve signal if it's all plastic?!" .. thinking that it was, seeing how it broke so easily.. nope. it's metal, and that metal snapped clean off.
looks sorta like a corroded battery terminal.. where can I get a new antenna assembly?
Midgear
Mcalester, OK
ShafferNY
Ticonderoga, NY
That's what happens when manufactures mix non-furious and furious metals. CORROSION. Too bad they didn't install some sacrificial anodes.
jcbll95
JPOTM WINNER
weston wv
Some kid, or moron adult for that matter, walking through a parking lot may have grabbed it and gave it a good fling and cracked it. and when you did it you just finished it off .......ya never know.
One thing is for sure it is not fun to access the inside antenna wire/connection.
The antenna x is a screw in replacement and Midgear you will need to pull the rear section of the fender forward to remove and replace with new exterior fitting, that can be obtained from dealer.
Alternatively you could temporarily use an interior radio type antenna and just make the connection radio rear.
Vtolds
Stowe, VT
Midgear
Mcalester, OK
or scrap the antenna all together and get satellite radio.. mabey put trail rated badges on either side where the antenna existed and on the driver side in the same spot-
my head unit is HD / satellite radio ready.
