Lift help
tenchikioto
tennessee
I want to thank you for this thread. I ordered on Friday from your list you posted. Learned a lot and help me decide between this and or going with OME. Now just need to decide on tires, grabber at2 or toyo open country at II.
Sent from my Galaxy Nexus using Tapatalk
Rhino
Surprise,Az
Good pics. How did you wire up the lights though? I have no experience in doing anything like that?
Rhino
Surprise,Az
Oright I found a thread on DIY part of the forum. But yours look like LED so I don't know if its different.
Rhino
Surprise,Az
Thought so. If anyone out there knows if their is a difference. Please help
Rhino
Surprise,Az
Ok, I don't know since I've been told HID's use a ballast and draw higher amperage. But wiring up is the same Pwr , Grnd, and relay to switch. Correct?
tevaly0102
Massachusetts
JBA makes great stuff but, I saved $100 with Rocky road outfitters upper control arms and yet to have an issue thus far. The only difference is mine are black and JBA is red.
Only difference is color :signs8::signs8:
Ok
TheSurvivor
Grand Island NY / Central Square NY
Ok have had the tommudd Eco lift on the jeep for a month now and figured I would post my per and post measurements
PRE LIFT
Front left - 18
Front right - 18 1/2
Rear left - 18
Rear right - 18 1/4
POST LIFT
Front left - 21 1/2
Front right - 21 1/2
Rear left - 22 3/4
Rear right - 22 3/4
Now I also have a question. Ever sense I put the lift on whenever I need to do an almost full or full turn I get a weird nose, like a banging or cranking sound. Does this mean I need to replace my cv's? If so do I need to get the cut down ones? Also is this about where I should be with this lift? And will I lose some of that when It settles?
KJScott
East Central Florida
Mine settled very little, rides great doesn't it?! Did you torque your sway bar and everything else when the KJ was back on the ground? You won't need cut down CVs with that lift. Only if you are going 4"+ over stock should you need them.
I am betting on sway bar noises. If you torqued all your bolts/ nuts with the KJ still on jack stands you should loosen them and retorque. Otherwise things are binding.
Ohio-white-kj
ohio
I never even removed or loosened the sway bar. Wonder if I should break it loose then re-tighten? Mines 2 1/2" higher that it was.
Hedsic
Des Moines, Iowa
Shouldn't I be sitting higher tho? I thought the lift was suposed to put me 3.5 over stock height, and isn't stock height at like 19.5?
I have the same lift. I'm sitting very close to 23" front (after adding larger clevis spacer) and 23" rear both sides. Factory height is 19"
You should be about 22.25-22.5
which clevis spacer did you get?
Not sure what happened along the line but the first set I got and installed on mine put me at 23 , its on 501s now and still about 22.75.
But using the largest clevis spacer gives you some more lift
Rhino
Surprise,Az
Dunno if I've said this b4, but ima say it now. This thread is extremely insightful to those of us that have not lifted our rigs. My self included!!
