Jeep won't start! DD! Help!
Found a company online that has a good replacement for 200 bucks, going to order it, and somehow get my car back from the shop and replace it myself. not paying them $1000 bucks to replace my steering column
Make sure you have all the correct tools to replace it,there are some specail tools required.Read up on disarming the airbag system correctly also.
TruLiberty
Northern Virginia, US
was able to just stick a screwdriver into the ignition switch, and turn the car on :) it will work for now till i get the replacement column, then i'll just swap it out.
TruLiberty
t-10 security torx and a pin push, got it. just need to figure out disarming the airbag...shouldnt be too bad, i have the repair manual
TruLiberty
now im debating if i should try and fix it(bondo+duct tape?), rig up a custom ignition solution( mount the ignition switch backwards and create a "key" for it out of wood or something), or just replace the steering column....
badkittystt
St. Thomas, USVI
I hate to interrupt this lovely conversation you're having with yourself... lol
I unfortunately have no input, just cracking up that every time I refresh the new posts there's another random thought.
TruLiberty
If i was paying more attention thankfully you would of derailed me, but unfortunately the self conversation continued for quite a while offline while i worked lol.
TruLiberty
Got the part in, but going to mexico on saturday so I don't want to mess with it yet. Today it started giving me a P0441 code now...when one thing goes i guess....so annoying.
TruLiberty
Does anyone know if i have to have to remove the steering wheel bolt to get the column out? i have all the bolts undone but i cant seem to pull it from the linkage
TruLiberty
Note: you don't have to remove the steering wheel, to replace the steering column. Also, there is a bolt at the linkage that you prolly shouldn't forget about. Libby is fixed! woot! Thanks for all the help guys!
mandyrt
ontario
im currently having the same problem. throughout my manual it mentions the how the mobil speed pass could interfere with the sentry key system. the RF that sends signal could become out of whack or something. MY dealership is having a hayday right now. its costing too much, does anyone know what im talking about? thanks
rockymountain
Spencerville, IN
