JBA adjustable struts
ktmrider
Northwest MS
Worth the extra expense? Anyone have the OME sturt and replaced them with the JBA's?
History of what I have ran in front since its the same either KJ or KK
OME 927
OME 790
Ironman HDs
JBA adjustables
Have also installed all of the above on others and rode in a lot that were lifted
Moving from stock to OME is like going from a ride of 1 or 2 to a 5 or 6 but going to the JBA adjustables is going to an 8.5 or 9 with ten being best
There is a considerable amount of difference. The JBA setup absorbs holes/ bumps etc way better . In my mind yes although expensive in a way, its worth it in the long run. Mine has 211,000 and rides the best it ever has. I have about 50,000 on the current setup
I've been running JBA 4 inch adjust a struts for the last 35,000 miles and love the setup. Much better than stock, which I had for the 35,000 miles before that. I don't have any experience with OME, but I would definitely take Tom's word for it.
ktmrider
Northwest MS
Actually meant to out this over in the KJ side. I'm so far ahead on this project with my budget I am going to get the JBA's.
OME 927
OME 790
Ironman HDs
JBA adjustables
.... and you couldn't have mentioned that when I was researching mine recently!??!!? bastard. :ROFLJest:
I thought most of the older members on here knew what all I had ran/ tested/ changed/ modified/ added to/ bent / broke etc :shrug::happy175:
I'm not that old (both in forum time as well as actual age.)
Oh well. I'll run 'em like they are until the struts/shocks wear out. the 90009's should be a massive step up from the old worn out STOCK setup.
Anything is a step up from the stock suspension , even low mileage stock:icon_lol:
Bmxer524
Lindenhurst, New York
I still have to install mine :icon_redface::icon_redface: I've had the kit for almost a year now, just haven't had time to install it.
I'll let you know when I get to it though. Then you'll have another stock, OME, JBA comparison.
wheeee32
Not the mountains.
The JBA's are very nice. I have them on mine. They definitely ride better than my Franky I had on the front. The install is much easier than the previous setup.
