Inc's Jeep Build
Inc
Free
Here is the Jeep stock, then Frankenlifted
Parts list for the SFA:
1. Front HP D30 out of an XJ, Solid Diff Cover, JKS control arm skids, 4.88's, Aussie Locker, Warn 5x4.5 Hub Kit, Warn inner and outer Chromo Shafts and the WJ knuckle/brake/steering conversion w/ chevy 3/4 ton TRE's and heavy duty 1.25x.219 drilled and tapped tie rod and drag link = $850
2. Rubicon Express Extended Steel Braided Brake Lines = $50 (do not buy these, they do not work and I am currently looking for a final solution)
3. Fox 2.0 Coil Over Shocks = $207 each (2) Fox-980-99-004-A
4. QA1 2.5id 10” #250 upper springs = $37 each (2)
5. QA1 2.5id 10” #300 lower springs = $37 each (2)
6. OME 864 Rear Springs = $75
7. Edelbrock #63914 Xtreme Travle IAS Medium Valving Rear Shocks = $35.95 each (2)
8. 35x12.5x15 Goodyear MT/R Kevlar = $196.60 ea. (4)
9. Rear 8.25 - 4.88 gears = $250
10. Rubicon Express Sway Bar Disconnects and TJ Sway Bar = $40
11. Front Drive Shaft = $275
12. Rear Drive Shaft = $375
13. Ford Steering Box = $90
14. Custom Exhaust = $400
15. Rubicon Express Long Arm Kit = $1,200
16. Long Arm and Coilover mounting = $350
17. Rubicon Express Extreme Duty Front Track Bar = $130
18. Yukon Alloy Axle Shafts for the Chrysler 8.25 = $250
Inc
Free
Jeep being taken apart for the build, out with the old - in with the new.
Long arms being mocked up and test fitting tires
Front suspension and steering components off the jeep
front axle under for measurements
Inc
Free
The front mounts for the engine and steering stuff, we plasma cut off the mounts we didn't need any longer and left on the engine mounts to avoid making new ones. We cleaned them up to make them look factory
Template for the unibody frame to be beefed up.
oddball
:cool:
So do you have a completion date in mind yet?
Inc
Free
First test fitting for the coilovers, we ended up moving them outboard like 2 more times.
Rear axle truss
Frame stiffeners for the rear half done
Inc
Free
Front half of the frame stiffeners and how they work with the t-case crossmember.
Inc
Free
The driver side engine mount taken back off and made to work with the built on track bar mount and steering box
crush sleeves for the steering box mounts in the unibody
output shaft on the steering box ground to fit the KJ pieces
Track bar
Inc
Free
Frame stiffeners, control arm mounts and new frame joiners all welded in and painted
Inc
Free
rear spring perches were moved back a few inches
Upper coilover mounts, hard to see the extra gussets, but there are 3 each side
Lower axle coilover mounts
Inc
Free
And here is where it sits as of today, still in the shop
Inc
Free
The jeep still need exhaust work, some new wheel studs to be pressed back in, a front driveline and rear 4.88s gears installed.
ramlebliberty
Wilmington, NC
Damn that is pretty, I'm diggin' the extended rear, beautiful job on that philly! The bumpers really set it off. Hopefully within the year I'll be going tube up front, you used a TJ bumper correct?
Great job, you made a monster!
Inc
Free
Yes I did. A TJ Fabtech Prerunner bumper from quadratec. $300 shipped. I then cut and welded in a Harbor Freight winch mounting plate. Works great.
ridenby
Gold Supporter
Kentucky
Looking great,followed your rockrail/boatside project earlier,maybe you could post it over here also?
Inc
Free
Sure thing, later today I'm going to post up all my other modifications I have done to my jeep.
Inc, that is just awesome.
There's nothing like the "click" of a manual locking hub in the morning.....and then you know you're in for some fun.....:D
Inc
Free
OK, I did a whole build thread of all the stuff I have done to my jeep, but since this the SFA section, I made a different build thread in the Member Journal Section.
NCC-1864
Quebec
A real pro job
First
let me say BRAVO
IT is a really nice and well execute modification
We can see all the welding details.
nicely painted.
your pictures shows us all the long hours you put on it.
There is not alot of SFA on liberty's in this world, but your is
a really good one.
Now were talking real
FLEX..........
Enjoy
Inc
Free
First
let me say BRAVO
nicely painted.
a really good one.
FLEX..........
Enjoy
Thank you. I wish it was done already so I could go out and put all the hard work to god use, but that will happen soon enough.
Staff online
