How do I remove dash panel?
Chillbilly
Maryville, TN
I have an irritating vibration sound from the small dash panel just to the left of the steering wheel. Can someone advise me how to remove it so that I can apply some insulation under it to get rid of the buzzing? This is on a 2005 Liberty. Thanks!
yellocoyote
NW Chicagoland
Start by pulling the little circle trim from the oh shit handle - there's a screw that lives under there that has to come out first. Requires a torx bit. Once the handle is out of the way, you'll see more screws... the rest is pretty self-explanatory.
Ry' N Jen
Just to the left of the steering wheel?
The little rectangular gray trim panel above the knee bolster?
If that is what I am thinking...
You can pop that off with a small flat blade screw driver.
If that's it, stuff a bit of paper between the clip and push it back in.
If that don't work, then just accept the fact that you own a Jeep and
they make little noises from time to time!
deliciousdaly
Fort Myers Florida
Mine does that too, I always had to push really ******* the flimsy piece of plastic by the vent. I just took some foam and shoved it in there.
