Front drive shaft
marky38
michigan
2007..had the front drive shaft removed this winter because of bad rear joint....well the shop kinda boogered the cap..I want to rebuild the joint..will this damaged cap effect the balance?...thanks
Robochop
Robochop
Virginia
The CV joint kits are available on ebay. There are plenty of Utube videos to show you the procedure. It's really easy but will make a mess! I would do both ends and Good luck.
