Factory Tow Package
nobody
NoDak
I bought my Jeep used, it came with a class 3 Mopar receiver installed. How do I know if this was done by the PO or if my Liberty came with the tow package? It's a 2004 automatic 4x4. It appears there may be a trans cooler in front of my radiator, however I couldn't find any max load tags on the vehicle. Where am I missing it?
Can request a build sheet from Mopar.
Is there a wiring harness (plug) back there too? If it came with the tow package it should have a wiring connector and a clutch fan on the water pump in addition to the efan in the shroud.
nobody
NoDak
Just the electric fan and a 4 prong wire harness for lights. No trailer brakes. So no tow package I take it. Thanks everyone.
TwoBobsKJ
Northern Ohio
Easy enough to add the mechanical fan and the shroud that surrounds it. You already have the transmission cooler (all V6 Libby's with a rare exception have the trans cooler) so the only thing missing is the extra fan and shroud. If you don't need a 7-pin for the extra power for the trailer and the wiring for installing a brake controller just stick with the 4-flat connector.
Here's how to add the mech fan and shroud.
Adam Roby
Montreal Canada
I decided to ask for my build sheet since I too am wondering if I have the tow package. This is the list they sent me, some interesting things... looks like it was a rental car... D'OH! How can it be that it only had 110,000 km on a 10-year old vehicle.
Cloth High-Back Bucket Seats
Med Slate Gray
Power Convenience Group
Monotone Paint
3.7L Eng (EKG)/4Spd A/T 42RLE (DG6)
136 Amp Alternator
600 Amp Maintenance Free Battery
Brake Assist
Electronic Stability Control
All Speed Traction Control
Anti-Lock 4-Wheel Disc Brakes
2nd Row Buckets, Power Fold/Tumble
Child Seat Anchor System-LATCH Ready
Advanced Multistage Front Air Bags
Floor Carpet
Cargo Compartment Carpet
Cargo Tie Down Loops
Plastic Swing Gate Trim Panel
Front & Rear Floor Mats
Cargo Trim Panel w/Storage Net
Passenger Assist Handles
Driver Assist Handle
Base Door Trim Panel
Full Length Floor Console
All 4-Speed Automatic Transmissions
4-Spd. Automatic 42RLE Transmission
Lock-Up Torque Converter
Command-Trac Part Time 4WD System
Dana 30/186MM Front Axle
3.73 Rear Axle Ratio
Corporate 8.25 Rear Axle
3.7L V6 Engine
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Flipper Swing Gate Glass
Rear Window Defroster
Rear View Day/Night Mirror
Sun Visors w/Illum Vanity Mirrors
Power Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Instrument Cluster w/Tach
240 KPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Dual Note Electric Horns
12V Auxiliary Power Outlet
Auxiliary 12-Volt Rear Power Outlet
Power Accessory Delay
Speed Sensitive Power Locks
Pwr Windows, Front 1-Touch Down
Med. GRAY - Molding - Bodyside, Acc
Med. GRAY - Fender Flares
Illuminated Entry
Map/Dome Reading Lamps
Cargo Compartment Lamp
Headlamp Off Time Delay
Halogen Headlamps
Daytime Running Headlamps, High Beam
Fog Lamps
CHMSL Lamp
Enhanced Accident Response System
Front License Plate Bracket
Body Color Grille
Gray Fascias
Trail Rated Badge
Jeep Badge
4X4 Badge
Side Roof Rails
3.7L Badge
Federal Emissions
Federal Tier 2, Bin 5 Emissions
20.5 Gallon Fuel Tank
Engine Block Heater
Speed Control
Low Vol Midnight Blue Pearl Coat
All Radio Equipped Vehicles
AM/FM Compact Disc Radio w/Chgr Ctrl
6 Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Jeep IS43 Suspension
Tilt Steering Column
Full Size Spare Tire
Outside Tire Carrier
P225/75R16 OWL All Season Tires
Goodyear Brand Tires
16X7.0 Lux Alum Silver Wheels
Matching Spare Wheel
All Aluminum Wheels
Occupant Classification System
Grocery Bag Hooks
Tethered Fuel Filler Cap
French/Canadian Language
Protective Coating and Remover
Build To Canada Mkt. Specifications
5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
GVW Rating - 5600#
Canada Dealer Retail
Zone 29-Canada-Fleet/Lease
Customer Preferred Package 2TB
Customer Preferred Package 28B
CAN-AM Warranty
Federal A/C Excise Tax
Exempt From Holdback
Sold Vehicle
Fleet Daily Rental Sale
Fleet Option Editor
Special Scheduling Condition II
Enterprise Rent-A-Car
Enterprise Rent-A-Car (Canada)
Four Wheel Drive (4WD)/(4X4)
Left Hand Drive (LHD)
KJ-Vehicle Family
Price Class H
Vehicle Order Tracking
Canada Specifications Label
Quebec Province Code
Anyone know specifically what would be written if it had the tow package?
Damn... Enterprise? Someone must have messed with the mileage no?
[/END THREADJACK] Sorry.
Mine has a tow package and lists as follows:
Sales Code Description
DL Prem Leather Trimmed Bucket Seats
L2 Lt Taupe/Taupe
ADLP Skid Plate Group
AHMS Convenience Group I
AHT Trailer Tow Group
AJBP Security Group
AJPS Power Convenience Group
APAS Monotone Paint
AWL Off Road Group
A33P 3.7L Eng(EKG)/4Spd A/T 45RFE(DG4)
BAZP 136 Amp Alternator
BCPS 525 Amp Maintenance Free Battery
BGK 4-Wheel Anti-Lock Brakes
CDBS Reclining Front Seats
CF5S 2nd Row Buckets, Power Fold/Tumble
CGGS Traveling Inboard Seat Belt Buckle
CGS Supplemental Side Air Bags
CGUS Child Seat Anchor System-LATCH Ready
CGXS RR Head Restraints Outboard Seating
CG1S Next Gen Multistage Front Air Bags
CG6S Center Rear 3-Point Seat Belt
CKBS Floor Carpet
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CLJP Jeep Rack Cargo Management Sys
CLNS Covered Exterior Sill
CLPS Door Sill Scuff Pads
CSAS Spare Tire Cover
CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CTCP Luxury Door Trim Panel
CUDP Mini Overhead Console
CUFS Full Length Floor Console
CUKS Removable Ash Tray
DGBS All 4-Speed Automatic Transmissions
DG4 Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHPP Selec-Trac Full Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRAP Corporate 8.25 Rear Axle
DSAP Trac-Lok Differential Rear Axle
EKG 3.7L V6 Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEKS Flipper Swing Gate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCP Sun Visors w/Illum Vanity Mirrors
GTSP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXMP Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
I23S Route 23 - CSX, Jessup, MD
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JJMP Auxiliary 12-Volt Rear Power Outlet
JKHS Glove Box
JPDS Power Windows, Driver One-Touch
JPHP Speed Sensitive Power Locks
JPM Heated Front Seats
JPTP Power Front Driver/Passenger Seats
K2BS PATRIOT BLUE P/C - Molding
K5BS PATRIOT BLUE P/C - Fender Flares,
LACP Illuminated Entry
LAJS Headlamps On Warning Chimes
LBBP Courtesy Lamps
LBDS Ash Tray Lamp
LCDP Map/Dome Reading Lamps
LDBP Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LHDS Headlamp Off Time Delay
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MDAP Front License Plate Bracket
MFKS Body Color Grille
MHAS Black Windshield Moldings
MLAS Body Color Fascias
MMGS Belt Moldings
MNAS Black Door Handles
MSUS Limited Edition Badge
MVCS Jeep Badge
MVDS 4X4 Badge
MWGS Side Roof Rails
MZLP 3.7L Badge
MZ3S Liberty Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBVP Low Emission Vehicle (LEV)
NF2S 18.5 Gallon Fuel Tank
NHFS Power Steering Cooler
NHMS Speed Control
NMCP Heavy Duty Engine Cooling
PB7 Patriot Blue Pearl Coat
QB7S Patriot Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RBPP AM/FM Cass/CD Radio w/Changer Ctrl
RCJP 6 Premium Infinity Speakers
RDDS Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
REM 6-Disc Remote CD Changer
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDAS Jeep IS43 Suspension
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TSNP P235/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WKBS Matching Spare Wheel
WLDS 16X7.0 Lux Aluminum Wheels
WLZC All Aluminum Wheels
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUS Front Suspension Skid Plate
XFJP Class III Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
XGDP Universal Garage Door Opener
XGGS Grocery Bag Hooks
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
Bummer on mine is that the PO must have removed the tow hooks and all the skids except the tcase and fuel tank. I also have no idea what this means: CF5S 2nd Row Buckets, Power Fold/Tumble.
TwoBobsKJ
Northern Ohio
...I also have no idea what this means: CF5S 2nd Row Buckets, Power Fold/Tumble.
I dunno either, but certain adult beverages have caused me to do a power fold and tumble right into a porcelain bucket :party52: :mexsmoke:
