Engine cut by driving
pivert
France
HELP : Engine cut by driving
Hello,
I have a big problem on my Jeep KJ 2002 V 3.7.
Sometimes, my engine cut off in driving on the road and I am forced to restart. The engine restart whithout any problems.
I have just one error on OBD : P0122. I tried to replace the throttle position sensor but the engine stalls with the new sensor. So I reinstalled the old sensor and the engine works well there.
According to the forums, my engine cutoff problem can come to Crankshaft Position Sensor. Can you confirm this?
Below, the position of Crank Position Sensor. Do you confirm ?
https://www.youtube.com/watch?v=PNdyzRIZpSE
http://www.jeepkj.com/forum/f225/crank-position-sensor-55143/
THanks for your help.
The code does relate to the TPS. What brand of TPS did you use? I used a Mopar TPS. You install by aligning up the tab a bit to right, then rotate back counter clockwise to install the TPS.
Before assuming any further sensors, please check to ensure your battery terminals are clean and super tight. Also get the battery load tested.
teeje
Toledo
It may also be a good idea to clean your throttle body with throttle body cleaner.
And the IAC valve. Cleaned mine a couple days ago. This is what she looked like. Gas mileage improved a lot for me also. Better idling as well.
pivert
France
The new sensor was a CROWN model.
The battery is good, but I don't have make a settings during the replacement...
