Emergency brake seems weak?
Brand0n1
Its an 04 i just bought used.
I park it in my drive that has a decent grade to it.
Thing is my other two cars emergency brakes would pretty much hold.
The Liberty's do not...
Even with a strong tug on it - it still creeps down until it hits park in the transmission.
Is this bad for the trans? Can the E brake be adjusted?
Is the Rig just too heavy?...
sailorbowman
michigan
Jeepster, I am going to try the parking/emergency brakes repair. It looks straight forward and obviously you know quite a bit about it.
Thanks from a fellow liberty lover
You can adjust the brakes at each side on the rear but adjusting the handle in the console only helps so long before it slips again. It works perfect until that clutch loosen up. Just wanted to make that aware.
jnaut
Seattle
Sometimes the ratchet assembly fails. Or at least that's what my dealer claimed when my first parking brake failed.
Billwill
White River, South Africa
I had the same problem from new with my 2002 CRD. At every service I asked for the emergancy brake (we call it a handbrake here!) to be adjusted. Finally when the Jeep was out of warranty the dealers replaced the racket assembly and that fixed it. They gave me the old one back, which I have since discarded, and it is quite a complicated device with a large spring wrapped around it which acts as a sort of one-way clutch.
I think this is where your problem lies!
matthewp
Buffalo, NY
...And I thought I was just a weak b!+@# not being able to pull it up far enough! Thanks for the how-to threads JeepJeepster.
mberthia
Michigan
I got in a habit of pulling so ******* the handbrake that the cable eventually broke...
jnaut
Seattle
Ya know, pretty much every KJ owner I talk to has the same problem with the Liberty's handbrake!
I believe it's a design defect. I seem to hear a lot about it too. I've had two fail on me in five years. I've never had a single handbrake fail on any other vehicle I've ever owned.
sleeve
Woodward Ave
This has to apply to the rear disk brake versions only. My drum style parking break will hold my Jeep off the parking pawl in almost every situation. It works flawlessly.
ShafferNY
Ticonderoga, NY
Just curious, but how many realize there is a proper "break in" when new parking brake shoes are installed?
I'm not trying to be critical. I just wonder how many know about it.
I've found with my Jeep, it's best to let off the service brakes very slowly to let the parking brake engage. My parking brake will hold my Jeep with a 14' aluminum boat & trailer on a boat launch ramp.
I have been using the slot screwdriver trick to take up slack on tab/adjuster..ya..ok..
I feel like cutting the brake cable and installing a manual adjuster on each side, just so I don't have to worry about cable stretch, and the fact that the auto adjuster is a complete piece of f***%n crap.
Staff online
